Zum Hauptinhalt wechseln
Razer Blade RZ09-0130 2015 Speaker Replacement
Was du brauchst
  1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 2 Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Speaker Replacement: Schritt 2, Bild 1 von 2 Razer Blade RZ09-0130 2015 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
  4. Razer Blade RZ09-0130 2015 Speaker Replacement: Schritt 4, Bild 1 von 2 Razer Blade RZ09-0130 2015 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
  5. Razer Blade RZ09-0130 2015 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Pick up and remove the speaker.
  6. Razer Blade RZ09-0130 2015 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Repeat the preceding steps to remove the second speaker.
Abschluss
Cal Poly, Team S18-G1, White Winter 2020 Mitglied von Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 344
