Zum Hauptinhalt wechseln
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
Was du brauchst
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: Schritt 1, Bild 1 von 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: Schritt 2, Bild 1 von 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: Schritt 3, Bild 1 von 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: Schritt 3, Bild 2 von 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: Schritt 3, Bild 3 von 3
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: Schritt 4, Bild 1 von 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: Schritt 5, Bild 1 von 1
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Abschluss
Cal Poly, Team S18-G1, White Winter 2020 Mitglied von Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 2,203
