Zum Hauptinhalt wechseln
Razer Blade Stealth 2016 Hard Drive Replacement
Was du brauchst
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down!
    Frag FixBot
    Kommentar hinzufügen
  2. Razer Blade Stealth 2016 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
    Frag FixBot
  3. Razer Blade Stealth 2016 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • The hard drive is located under the fan on the left side as shown in the picture!
    Frag FixBot
  4. Razer Blade Stealth 2016 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
    Frag FixBot
  5. Razer Blade Stealth 2016 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Razer Blade Stealth 2016 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
    Frag FixBot
  6. Razer Blade Stealth 2016 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Razer Blade Stealth 2016 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Carefully slide the hard drive out from its slot.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S1-G4, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 39
Insgesamt: 3,539
