Zum Hauptinhalt wechseln
Razer Blade Stealth 2016 Heat Sink Replacement
Was du brauchst
  1. Razer Blade Stealth 2016 Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 3 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: Schritt 1, Bild 2 von 3 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
    Frag FixBot
    Kommentar hinzufügen
  2. Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 2, Bild 1 von 2 Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
    Frag FixBot
  3. Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
    Frag FixBot
  4. Razer Blade Stealth 2016 Heat Sink Replacement, Fans: Schritt 4, Bild 1 von 2 Razer Blade Stealth 2016 Heat Sink Replacement, Fans: Schritt 4, Bild 2 von 2
    • Remove the three 3.38 mm screws from the left fan (this fan should be black).
    Frag FixBot
  5. Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • Carefully lift and remove the left fan.
    Frag FixBot
  6. Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 6, Bild 1 von 3 Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 6, Bild 2 von 3 Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 6, Bild 3 von 3
    • Repeat steps five and six to remove the silver, right fan.
    Frag FixBot
  7. Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: Schritt 7, Bild 1 von 2 Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: Schritt 7, Bild 2 von 2
    • Remove the four 3.38 mm screws around the black square using a Phillips #00 screwdriver.
    Frag FixBot
  8. Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 8, Bild 1 von 3 Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 8, Bild 2 von 3 Razer Blade Stealth 2016 Heat Sink Replacement: Schritt 8, Bild 3 von 3
    • Once the screws are removed, the piece can be gently lifted from the back of the device.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S1-G4, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 54
Insgesamt: 1,860
