Zum Hauptinhalt wechseln
Razer Blade Stealth 2016 Keyboard Replacement
Was du brauchst
  1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 2, Bild 1 von 2 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Keyboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 7, Bild 1 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 7, Bild 2 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: Schritt 9, Bild 1 von 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: Schritt 9, Bild 2 von 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: Schritt 9, Bild 3 von 3
    • Flip all white tabs up to unlock three ZIF connectors using the opening tool.
    • Flip all black tabs up to unlock the three ZIF connectors using the opening tool.
    • This is how the tabs look in the flipped up position.
  10. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 10, Bild 1 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 10, Bild 2 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 10, Bild 3 von 3
    • Pull the cables out gently.
  11. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 11, Bild 1 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 11, Bild 2 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 11, Bild 3 von 3
    • Remove fifty-five 3.4 mm keyboard screws with the T5 Torx screwdriver.
    • 5 screw locations are highlighted but locate all 55 screws and remove them.
  12. Razer Blade Stealth 2016 Keyboard Replacement: Schritt 12, Bild 1 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 12, Bild 2 von 3 Razer Blade Stealth 2016 Keyboard Replacement: Schritt 12, Bild 3 von 3
    • Remove the keyboard from the laptop.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,200
