Zum Hauptinhalt wechseln
Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement
Was du brauchst
  1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: Schritt 1, Bild 2 von 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
    Frag FixBot
    Kommentar hinzufügen
  2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 2, Bild 1 von 2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
    Frag FixBot
  3. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
    Frag FixBot
  4. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: Schritt 4, Bild 1 von 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: Schritt 4, Bild 2 von 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: Schritt 4, Bild 3 von 3
    • Carefully remove the auxiliary and main wire from the Killer 1535 wireless card.
    Frag FixBot
  5. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 5, Bild 1 von 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 5, Bild 2 von 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the two 2.61 mm screw holding the card in place.
    Frag FixBot
  6. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 6, Bild 1 von 2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the card.
    Frag FixBot
Abschluss
USF Tampa, Team S1-G4, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 1,323
