Zum Hauptinhalt wechseln
Razer Blade Stealth 2016 Speakers Replacement
Was du brauchst
  1. Razer Blade Stealth 2016 Speakers Replacement, Battery: Schritt 1, Bild 1 von 3 Razer Blade Stealth 2016 Speakers Replacement, Battery: Schritt 1, Bild 2 von 3 Razer Blade Stealth 2016 Speakers Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
    Frag FixBot
    Kommentar hinzufügen
  2. Razer Blade Stealth 2016 Speakers Replacement: Schritt 2, Bild 1 von 2 Razer Blade Stealth 2016 Speakers Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
    Frag FixBot
  3. Razer Blade Stealth 2016 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
    Frag FixBot
  4. Razer Blade Stealth 2016 Speakers Replacement, Speakers: Schritt 4, Bild 1 von 1
    • Remove two 3.4 mm screws from each speaker using a T4 Torx screwdriver.
    • Remove the speakers from the laptop.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 405
