Zum Hauptinhalt wechseln
Razer Blade Stealth 2017 Audio and USB-A Port Replacement
Was du brauchst
  1. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: Schritt 1, Bild 1 von 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 3, Bild 1 von 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 5, Bild 1 von 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 5, Bild 2 von 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: Schritt 6, Bild 1 von 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: Schritt 6, Bild 2 von 2
    • Use a plastic spudger to lift up the module connector.
  7. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 7, Bild 1 von 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
  8. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: Schritt 8, Bild 1 von 1
    • Use a plastic spudger to remove the USB-A and audio port module from the chassis.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S11-G3, Regan Fall 2019 Mitglied von Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 1,715
