Einleitung
This guide outlines how to replace the audio and USB-A port module in the Razer Blade Stealth 2017. The audio may be faint or not work. This module is found on the left-hand side of the laptop and often has issues regarding loose ports and external device communication. Some tools are required for this replacement.
Was du brauchst
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
Use a plastic spudger to remove the USB-A and audio port module from the chassis.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
