Einleitung
This guide outlines how to remove the display assembly of the Razer Blade Stealth 2017. Display assembly replacement may be necessary if there are cracks or breaks on the screen, dead or stuck pixels that show one color or no color at all, lines, spots, or blobs on the screen, flickering or fading of the backlight, distorted colors or contrast, blurry or ghost images, and no image or signal. Some tools are required for this replacement.
Was du brauchst
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Use a Phillips #00 screwdriver to remove the six 4 mm screws securing the display assembly.
Use the plastic spudger to slide the connectors to the right to disconnect them.
Lift the screen to the open position.
Remove the display assembly by sliding it away from the keyboard.
Eine weitere Person hat diese Anleitung absolviert.
