Zum Hauptinhalt wechseln
Razer Blade Stealth 2017 Display Assembly Replacement
Was du brauchst
  1. Razer Blade Stealth 2017 Display Assembly Replacement, Battery: Schritt 1, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 3, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 5, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 5, Bild 2 von 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: Schritt 6, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws securing the display assembly.
  7. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 7, Bild 1 von 3 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 7, Bild 2 von 3 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 7, Bild 3 von 3
    • Use the plastic spudger to remove the plastic brackets beneath the hinges.
  8. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 8, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 8, Bild 2 von 2
    • Remove any tape attached to the wires.
    • Use the plastic spudger to slide the connectors to the right to disconnect them.
  9. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 9, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 9, Bild 2 von 2
    • Use the plastic spudger to lift the connector off of the socket.
  10. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 10, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 10, Bild 2 von 2
    • Use your fingers to lift connectors off of their sockets.
  11. Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 11, Bild 1 von 2 Razer Blade Stealth 2017 Display Assembly Replacement: Schritt 11, Bild 2 von 2
    • Lift the screen to the open position.
    • Remove the display assembly by sliding it away from the keyboard.
    • Do not force the display assembly off!
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kris Ritter
163 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 51
