Einleitung
This guide outlines how to replace the fans in the Razer Blade Stealth 2017. The fans keep the laptop cool and prevent the other components from overheating. A fan replacement may be necessary if the fans are damaged, not turning on, or not functioning optimally. If the fans are making abnormally loud sounds when running, they may need to be replaced. Some tools are required for this replacement.
Was du brauchst
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Use tweezers to pull the fan cable out of the opened connector terminal.
Use tweezers to squeeze the fan's white header.
Disconnect the fan connector by sliding it out toward the rear of the chassis.
Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
