Zum Hauptinhalt wechseln
Razer Blade Stealth 2017 Keyboard Replacement
Was du brauchst
  1. Razer Blade Stealth 2017 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Razer Blade Stealth 2017 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 3, Bild 1 von 2 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 5, Bild 1 von 2 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Keyboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 Razer Blade Stealth 2017 Keyboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 Razer Blade Stealth 2017 Keyboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Use a plastic spudger to gently undo the connections to the motherboard.
  7. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 7, Bild 1 von 3 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 7, Bild 2 von 3 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws holding the display hinges on both side.
    • Remove the small plastic brackets holding the display hinges.
  8. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the 2.6 mm screw holding the Wi-Fi card down with a Phillips #00 screwdriver.
    • Remove the motherboard from the laptop.
  9. Razer Blade Stealth 2017 Keyboard Replacement, Keyboard: Schritt 9, Bild 1 von 2 Razer Blade Stealth 2017 Keyboard Replacement, Keyboard: Schritt 9, Bild 2 von 2
    • Carefully remove tape from the keyboard.
  10. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 10, Bild 1 von 2 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Pull out the cables carefully.
  11. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 11, Bild 1 von 2 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the fifty-five 1.6mm screws securing the keyboard.
    • Not all the screws are highlighted.
  12. Razer Blade Stealth 2017 Keyboard Replacement: Schritt 12, Bild 1 von 3 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 12, Bild 2 von 3 Razer Blade Stealth 2017 Keyboard Replacement: Schritt 12, Bild 3 von 3
    • Carefully pick up the keyboard from both sides in order to remove the keyboard.
    • Use a spudger if necessary to remove the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Nolan Wilkins
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 52
