Zum Hauptinhalt wechseln
Razer Blade Stealth 2017 Touchpad Replacement
Was du brauchst
  1. Razer Blade Stealth 2017 Touchpad Replacement, Battery: Schritt 1, Bild 1 von 2 Razer Blade Stealth 2017 Touchpad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 3, Bild 1 von 2 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 5, Bild 1 von 2 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Touchpad Replacement, Motherboard: Schritt 6, Bild 1 von 3 Razer Blade Stealth 2017 Touchpad Replacement, Motherboard: Schritt 6, Bild 2 von 3 Razer Blade Stealth 2017 Touchpad Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Use a plastic spudger to gently undo the connections to the motherboard.
  7. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 7, Bild 1 von 3 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 7, Bild 2 von 3 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws holding the display hinges on both side.
    • Remove the small plastic brackets holding the display hinges.
  8. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Remove the 2.6 mm screw holding the Wi-Fi card down with a Phillips #00 screwdriver.
    • Remove the motherboard from the laptop.
  9. Razer Blade Stealth 2017 Touchpad Replacement, Touchpad: Schritt 9, Bild 1 von 2 Razer Blade Stealth 2017 Touchpad Replacement, Touchpad: Schritt 9, Bild 2 von 2
    • Use a Phillips #000 to remove all 55 1.6 mm screws from the metal plate.
    • Remove the metal plate from computer using your hands.
  10. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 10, Bild 1 von 3 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 10, Bild 2 von 3 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 10, Bild 3 von 3
    • Use a spudger to remove foil tape.
    • Pull the connectors off using fingers
    • Remove the connectors by lifting up the hinges by using fingertips.
    • Pull the connectors off.
  11. Razer Blade Stealth 2017 Touchpad Replacement: Schritt 11, Bild 1 von 3 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 11, Bild 2 von 3 Razer Blade Stealth 2017 Touchpad Replacement: Schritt 11, Bild 3 von 3
    • Pull the connector off from the mousepad connected to the daughterboard.
    • Use a Jimmy to remove adhesive from the metal bracket on the mousepad.
    • To remove adhesive, warm the area up that has adhesive.
    • Pull up on the metal bracket after removing adhesive.
    • Push down on the mousepad to remove from the computer.
Abschluss
Jovanny Reyes
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 52
