Einleitung
This guide outlines how to change the touchpad in the Razer Blade Stealth 2017. The touchpad breaking may be a result of a missing or out-of-date driver. Updating or reinstalling your touchpad drivers in Device Manager may help solve the problem. Some tools are required for this replacement.
Was du brauchst
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Use a plastic spudger to gently undo the connections to the motherboard.
Use a Phillips #00 screwdriver to remove the six 4 mm screws holding the display hinges on both side.
Remove the small plastic brackets holding the display hinges.
Remove the 2.6 mm screw holding the Wi-Fi card down with a Phillips #00 screwdriver.
Remove the motherboard from the laptop.
Use a Phillips #000 to remove all 55 1.6 mm screws from the metal plate.
Remove the metal plate from computer using your hands.
Use a spudger to remove foil tape.
Pull the connectors off using fingers
Remove the connectors by lifting up the hinges by using fingertips.
Pull the connectors off.
Pull the connector off from the mousepad connected to the daughterboard.
Use a Jimmy to remove adhesive from the metal bracket on the mousepad.
Pull up on the metal bracket after removing adhesive.
Push down on the mousepad to remove from the computer.
