Zum Hauptinhalt wechseln
Razer DeathAdder Chroma Scroll Wheel Replacement
Was du brauchst
  1. Razer DeathAdder Chroma Scroll Wheel Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 2, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 2, Bild 2 von 2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 3, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 4, Bild 1 von 1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 6, Bild 1 von 3 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 6, Bild 2 von 3 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 6, Bild 3 von 3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 7, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma Scroll Wheel Replacement, Motherboard: Schritt 8, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement, Motherboard: Schritt 8, Bild 2 von 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 9, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 10, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 10, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 11, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 12, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 13, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement: Schritt 13, Bild 2 von 2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma Scroll Wheel Replacement, Scroll Wheel: Schritt 14, Bild 1 von 2 Razer DeathAdder Chroma Scroll Wheel Replacement, Scroll Wheel: Schritt 14, Bild 2 von 2
    • Remove the scroll wheel from the socket by pulling to the right.
    • Pulling too hard could damage the scroll wheel connector.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Corrie Tung
702 Reputation
2 Anleitungen geschrieben
Baylor, Team S5-G2, Williams Spring 2017 Mitglied von Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 58
Insgesamt: 18,723
