Einleitung
The Razer DeathAdder Chroma may experience critical issues related to the device not being registered by the computer via a fault in the USB cable.
Was du brauchst
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
Disconnect the ribbon connector between the motherboard and the optical sensor.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Thanks for the advice
Is there a reliable website where I can get a replacement cable with low delivery time?
where can i get the cable from?
