Was du brauchst
Turn off the mouse by holding the power button for 3 seconds.
The light on top will blink red, indicating its been turned off.
Slide your fingernail or a pair of tweezers under the skates and pull up.
I found using my finger to finish peeling the skates off was easier, but your mileage may vary.
If there is a leftover paper like material, remove it just like you did the skates.
Use the included alcohol prep pad, or your own, to remove any leftover residue.
Place your new skates in the correct spot.
Apply some pressure with your thumb to make sure that the skates stick properly.
Use your tweezers or fingers to pop out the extra piece for the sensor ring.
