Zum Hauptinhalt wechseln
Razer Huntsman TE Keycaps Replacement
Was du brauchst
  1. Razer Huntsman TE Keycaps Replacement, Keycaps: Schritt 1, Bild 1 von 2 Razer Huntsman TE Keycaps Replacement, Keycaps: Schritt 1, Bild 2 von 2
    • Identify the correct type of key to replace.
    • Keys such as "Shift" and "Enter" have multiple slots, and each slot has a different shape, so be sure to pick the correct one.
  2. Razer Huntsman TE Keycaps Replacement: Schritt 2, Bild 1 von 2 Razer Huntsman TE Keycaps Replacement: Schritt 2, Bild 2 von 2
    • Insert the keycap puller so that the teeth at the end of the puller sit beneath the keycap.
    • Apply enough upwards force for the keycap to pop out.
  3. Razer Huntsman TE Keycaps Replacement: Schritt 3, Bild 1 von 2 Razer Huntsman TE Keycaps Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Microfiber Cleaning Cloths
    $3.99
    Kaufen
    • Apply 91% isopropyl alcohol to microfiber cloth.
    • Wipe around the key.
    • Make sure that there is no residual stickiness on the key.
  4. Razer Huntsman TE Keycaps Replacement: Schritt 4, Bild 1 von 2 Razer Huntsman TE Keycaps Replacement: Schritt 4, Bild 2 von 2
    • Position the replacement keycap above the keyslot.
    • Using your finger, apply downwards force to the keycap until you hear it snap into place.
Abschluss
Use a diagnostic tool such as an online keyboard tester to test the key.
Lucas de Castro
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 46
Insgesamt: 1,958
