Zum Hauptinhalt wechseln
Razer Kishi V2 Pro D-Pad Replacement
Was du brauchst
  1. Razer Kishi V2 Pro D-Pad Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Put the device down with the bottom facing up.
    • Remove the eight 12 mm screws from the back of the controller using a T5 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Razer Kishi V2 Pro D-Pad Replacement: Schritt 2, Bild 1 von 3 Razer Kishi V2 Pro D-Pad Replacement: Schritt 2, Bild 2 von 3 Razer Kishi V2 Pro D-Pad Replacement: Schritt 2, Bild 3 von 3
    • Gently apply light pressure to the front top half of the controller and slowly lift it up.
    • When you hear a click, the two halves should be successfully disconnected.
    • When you separate the two parts from each other, two of the back bumpers might fall out. If the bumpers do fall out don't worry because they just snap back in.
    • Be careful when doing this, if you apply too much pressure you could rip the ribbon cable.
    • Repeat for the opposite side of the controller.
    Frag FixBot
  3. Razer Kishi V2 Pro D-Pad Replacement, D-Pad: Schritt 3, Bild 1 von 2 Razer Kishi V2 Pro D-Pad Replacement, D-Pad: Schritt 3, Bild 2 von 2
    • Using tweezers or your fingers, remove the D-pad from the silicone pad.
    • Make sure not to pull out the silicone pad.
    Frag FixBot
Abschluss
Epiphany Johnson
76 Reputation
1 Anleitung geschrieben
Austin Community College, Team 1-1, Watkins Spring 2025 Mitglied von Austin Community College, Team 1-1, Watkins Spring 2025
AUSTINCC-WATKINS-S25S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 38
Insgesamt: 407
