Einleitung
This is a guide on replacing the D-pad on the Razor Kishi v2 Pro. This guide will walk you through the simple process of replacing it. With easy-to-follow steps, you’ll have your controller's D-pad restored to its original condition and ready for smooth, precise gameplay. Let’s get started and bring your Razor Kishi V2 Pro back to life!
Was du brauchst
Put the device down with the bottom facing up.
Remove the eight 12 mm screws from the back of the controller using a T5 screwdriver.
Gently apply light pressure to the front top half of the controller and slowly lift it up.
Repeat for the opposite side of the controller.
