Zum Hauptinhalt wechseln
Razer Kishi v2 Pro L1 R1 Bumpers Replacement
Was du brauchst
  1. Razer Kishi v2 Pro L1 R1 Bumpers Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Put the device down with the bottom facing up.
    • Remove the eight 12 mm screws from the back of the controller using a T5 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Razer Kishi v2 Pro L1 R1 Bumpers Replacement: Schritt 2, Bild 1 von 3 Razer Kishi v2 Pro L1 R1 Bumpers Replacement: Schritt 2, Bild 2 von 3 Razer Kishi v2 Pro L1 R1 Bumpers Replacement: Schritt 2, Bild 3 von 3
    • Gently apply light pressure to the front top half of the controller and slowly lift it up.
    • When you hear a click, the two halves should be successfully disconnected.
    • When you separate the two parts from each other, two of the back bumpers might fall out. If the bumpers do fall out don't worry because they just snap back in.
    • Be careful when doing this, if you apply too much pressure you could rip the ribbon cable.
    • Repeat for the opposite side of the controller.
    Frag FixBot
  3. Razer Kishi v2 Pro L1 R1 Bumpers Replacement, L1 R1 Bumpers: Schritt 3, Bild 1 von 1
    • The L1 and R1 bumpers might fall out of their place; if they don't, just grab the bumper and pull on them and they will come right out of their slots.
    • There are two parts of the bumpers: the actual bumper itself and a spring.
    Frag FixBot
Abschluss
Austin Community College, Team 1-1, Watkins Spring 2025 Mitglied von Austin Community College, Team 1-1, Watkins Spring 2025
AUSTINCC-WATKINS-S25S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 27
Insgesamt: 368
