Einleitung
Have you ever bought a new Razer Mamba mouse due to the scroll wheel not working or acting clunky on an old mouse? Well, this guide will help people save money by helping them fix their clunky scroll wheel without having to replace their entire mouse. All that is needed to fix your mouse is a couple of tools and hydrogen peroxide. This guide will be fairly simple but will leave your mouse working brand new without having to buy a new one.
Was du brauchst
Remove the single screw using a Phillips #000 screwdriver.
Peel back the sticker on the mouse to reveal the two screws behind it.
Remove the two screws using a Phillips #000 screwdriver.
Use an iFixit opening tool to pry open your mouse.
Detach the ribbon cable by squeezing the two grey latches and pulling it out gently.
Use your hands to lift the battery out of the mouse.
Use your fingers to detach the cable from the mouse.
Unscrew the five 1.4 mm screws using the Phillips #000 screwdriver.
Detach the wire that is connected to the scroll wheel.
Dip a cotton swab in hydrogen peroxide.
Clean the scroll wheel by dabbing the cotton swab around it.
Reinsert the wire back into its socket.
Insert and tighten the five 1.4 mm screws with the Phillips #000 screwdriver.
Connect the battery wire back into the latch.
Put the battery back into the battery holder.
Connect the wire back into the latch.
Screw back the three screws using a Phillips #000 screwdriver.
Replace the sticker that was covering the top two screws.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Listen screw driver is incorrect. Poor disassembly instructions that can easily lead to further irreparable damage to the mouse. Incredibly disappointing
Cry me a river! If the screwdriver is incorrect i.e., doesn't fit into the screw correctly, don't attempt to make it work but instead try a different sized screwdriver. Wow! What a concept! Quit with the dramatics and just be glad that Kevin took the time to make this guide.
