Zum Hauptinhalt wechseln
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement, Ear Cushions: Schritt 1, Bild 1 von 1
    • The ear cushions are removed from the device by slightly different methods.
    • To remove the left ear cushion (the side with the boom), rotate the cushion counter clockwise as far as it can turn, then pull the ear cushion straight out from the device.
    • To remove the right ear cushion, rotate it clockwise as far as it can turn, then pull the ear cushion straight out from the device.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement: Schritt 2, Bild 1 von 1
    • In order to remove the cushion from the plastic backing, slide the leather free of the plastic edge, working around the entire cushion until it separates.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle Schober
640 Reputation
5 Anleitungen geschrieben
Michigan Tech, Team 5-8, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 1,705
