Zum Hauptinhalt wechseln
Einleitung
This guide will detail how to disassemble the maelstrom audio control device and repair a damaged wire connection.
Ersatzteile
Keine Ersatzteile angegeben.
  1. To get to the maelstrom wiring you must first pull off the plastic cover. To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate. Then remove the four 8.5mm screws on the back plate of the maelstrom.
    • To get to the maelstrom wiring you must first pull off the plastic cover.
    • To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
    • Then remove the four 8.5mm screws on the back plate of the maelstrom.
  2. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  3. Once the four screws are removed, the top cover can be lifted off. There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
    • Once the four screws are removed, the top cover can be lifted off.
    • There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
    • Remove the three 2mm screws from the circuit board to separate it from the back plate.
  4. The circuit board is now completely separate from the housing and the wires can now be inspected. Peel back the tape on the wires to inspect any damage to the wires if there is any.
    • The circuit board is now completely separate from the housing and the wires can now be inspected.
    • Peel back the tape on the wires to inspect any damage to the wires if there is any.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Kyle Schober
622 Reputation
5 Anleitungen geschrieben
Michigan Tech, Team 5-8, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Mitglieder
9 Anleitungen geschrieben
Well for the last step the wires I peeled the wires by burning them on a gas ranger. Worked Perfectly.
Edwin Lopez - Antwort
can you provide the connection map for the cables that go prom remote root to headphones?
johnny1992black - Antwort
comeon you wanna tell me you took picture of the cables from one side and the other one not this is a joke right?
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 4,933
