Zum Hauptinhalt wechseln
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement
Was du brauchst
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • If the damaged speaker is in the left ear piece, remove the left ear cushion by rotating it counter clockwise (ear piece with microphone boom). For the right speaker, the right ear cushion must be turned clockwise to remove.
    • For additional information on removing the ear cushions, reference the Ear Cushions replacement guide.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: Schritt 2, Bild 1 von 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: Schritt 2, Bild 2 von 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: Schritt 2, Bild 3 von 3
    • To get to the speaker you need to remove the six 5mm screws from the inner housing plate.
    • After doing this you can pull the housing apart exposing the speaker.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: Schritt 3, Bild 1 von 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: Schritt 3, Bild 2 von 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: Schritt 3, Bild 3 von 3
    • Use a knife to cut the glue around the speaker that is holding it to the assembly.
    • Once the glue is cut, pry the speaker out. Cut the wires at the base of the speaker and then replace them.
    • A solder gun will be needed to solder the wires onto the new speaker.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle Schober
640 Reputation
5 Anleitungen geschrieben
Michigan Tech, Team 5-8, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Mitglieder
13 Anleitungen geschrieben
3 Kommentare
Great guide!!
What speaker do i need to buy, where can i buy it ?
thank you!
Tom Van Aken - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 4,293
