Zum Hauptinhalt wechseln
Razer Naga Epic Chroma Side Button Connection Strip Replacement
Was du brauchst
  1. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Razer Naga Epic Chroma Disassembly: Schritt 1, Bild 1 von 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 3, Bild 1 von 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 4, Bild 1 von 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Battery: Schritt 5, Bild 1 von 1
    • Take your nylon spudger to gently pry the battery pack from the device.
    • Remove the foam on the battery shell for your new battery.
  6. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 6, Bild 1 von 1
    • Unplug the power cord from the circuit board in the mouse.
  7. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 7, Bild 1 von 1
    • Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
    • Insert the new battery into the battery socket.
    • Place the foam on the surface of the new battery (reference Step 5).
  8. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Side Button Connection Strip: Schritt 8, Bild 1 von 1
    • Under the battery, remove the two screws holding the battery mount in place.
    • Remove the battery mount.
  9. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 9, Bild 1 von 1
    • Flip open the black pieces on either end of the white connection strip holding the side buttons onto the circuit board.
  10. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 10, Bild 1 von 1
    • Gently pull the white connection strip out of both connection ports.
  11. Razer Naga Epic Chroma Side Button Connection Strip Replacement: Schritt 11, Bild 1 von 1
    • Insert the blue stripes of the new white connection strip into both white connection points.
    • One connection point is on the plastic plate that has the buttons. The second connection point is where the battery mount was.
Abschluss
2 Kommentare
Where can i buy a new Strip?
Rathura - Antwort
Did you find the strip? Im looking or it as well.
Tsuki Yomi -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 2,635
