Was du brauchst
Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
Gently pull up on the right plate on the mouse; separating it.
Carefully repeat this step for the left side.
Plug the new top casing's cable back into the socket on the right side of the circuit board near the middle.
Reassemble the device.
Test device to make sure the connections function correctly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
