Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This prerequisite guide is to help users disassemble the mouse. The mouse needs to be mostly disassembled in order to complete most of the tasks needed to fix any issues.
Put on the anti-static wrist strap to protect you from electrostatic discharges during your repair.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the interchangeable side plate. Remove the interchangeable side plate.
    • Remove the interchangeable side plate.
  2. Remove the mouse's feet using the opening pick. Remove the mouse's feet using the opening pick.
    • Remove the mouse's feet using the opening pick.
  3. Remove the four 6mm screws by using a JIS #1 screwdriver.
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Separate the top mouse housing from the bottom mouse housing using the opening pick. Be careful not to tug too hard on the ribbon connector.
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Remove the side housing using the opening pick.
    • Remove the side housing using the opening pick.
  7. Remove the top housing LED 3-Pin connector that is near the main board. Remove the top housing LED 3-Pin connector that is near the main board.
    • Remove the top housing LED 3-Pin connector that is near the main board.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
I would like to to point out that at step 7, second picture, the 3-pin connector is for the top 2 buttons. the RGB LED is actually in the board and can be seen in step 7 first picture, tiny white square at the bottom, top left where it says K7-D1.
Jaidee Sasaki - Antwort
The cable for the Naga2014 fits admirably and appears to work fully, BUT NOTE: the green and white wires need to be swapped around in the plug at the end that connects inside the mouse.
Chris Gravell - Antwort
How do you open up the side plates so you can clean inside them?
Teach - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 25
Letzten 7 Tage: 165
Letzten 30 Tage: 739
Insgesamt: 9,554
