Zum Hauptinhalt wechseln
Razer Naga Trinity LK-E5 Optical Encoder Replacement
Was du brauchst
  1. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: Schritt 1, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: Schritt 1, Bild 2 von 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 2, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 2, Bild 2 von 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 4, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 4, Bild 2 von 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 5, Bild 1 von 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 6, Bild 1 von 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 7, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 7, Bild 2 von 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: Schritt 8, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: Schritt 8, Bild 2 von 2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 9, Bild 1 von 1
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 10, Bild 1 von 1
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 11, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 11, Bild 2 von 2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 12, Bild 1 von 3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 12, Bild 2 von 3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 12, Bild 3 von 3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
  13. Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: Schritt 13, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: Schritt 13, Bild 2 von 2
    • Remove the scroll wheel from the scroll wheel housing using the opening tool.
  14. Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 14, Bild 1 von 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: Schritt 14, Bild 2 von 2
    • Remove the scroll wheel optical encoder from the scroll wheel.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Where can we buy a replacement from?
Daniel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 60
Insgesamt: 2,101
