Zum Hauptinhalt wechseln
Razer Naga Trinity Scroll Wheel Housing Replacement
Was du brauchst
  1. Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: Schritt 1, Bild 1 von 2 Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: Schritt 1, Bild 2 von 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 2, Bild 1 von 2 Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 2, Bild 2 von 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 4, Bild 1 von 2 Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 4, Bild 2 von 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 5, Bild 1 von 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 6, Bild 1 von 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 7, Bild 1 von 2 Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 7, Bild 2 von 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: Schritt 8, Bild 1 von 2 Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: Schritt 8, Bild 2 von 2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 9, Bild 1 von 1
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 10, Bild 1 von 1
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 11, Bild 1 von 2 Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 11, Bild 2 von 2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 12, Bild 1 von 3 Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 12, Bild 2 von 3 Razer Naga Trinity Scroll Wheel Housing Replacement: Schritt 12, Bild 3 von 3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kristen Gismondi
81.767 Reputation
200 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
2 Kommentare
can you give a link for a replacement scroll wheel if possible?
joe - Antwort
nice guide but i sadly didn’t found any housing wheel replacement part ><
Zzz Zzz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 106
Insgesamt: 4,251
