Zum Hauptinhalt wechseln
Razer Ouroboros Battery Replacement
Was du brauchst
  1. Razer Ouroboros Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin by turning the mouse upside down.
    • Use a Phillips #00 to loosen the two captive screws circled in the first image.
    • These screws do NOT come out, they merely loosen.
    • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
  2. Razer Ouroboros Battery Replacement: Schritt 2, Bild 1 von 1
    • This is the bottom of the palm rest.
    • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
  3. Razer Ouroboros Battery Replacement: Schritt 3, Bild 1 von 1
    • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
    • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
    • You must use rechargeable batteries in this mouse.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Memphis, Team 1-2, Kim SU 2016 Mitglied von University of Memphis, Team 1-2, Kim SU 2016
UM-KIM-SU16S1G2
3 Mitglieder
4 Anleitungen geschrieben
8 Kommentare
is the battery a standard AA battery size or did they use a different size?
adiforipod - Antwort
Standard AA size mate
Minty Fox - Antwort
… what happens if I don't use a rechargeable battery?
Russell Phillips - Antwort
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 -
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 49
Insgesamt: 19,697
