Zum Hauptinhalt wechseln
Razer Phone Battery Replacement
Was du brauchst
  1. Razer Phone Battery Replacement, Display Assembly: Schritt 1, Bild 1 von 3 Razer Phone Battery Replacement, Display Assembly: Schritt 1, Bild 2 von 3 Razer Phone Battery Replacement, Display Assembly: Schritt 1, Bild 3 von 3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Battery Replacement: Schritt 2, Bild 1 von 2 Razer Phone Battery Replacement: Schritt 2, Bild 2 von 2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Battery Replacement: Schritt 3, Bild 1 von 3 Razer Phone Battery Replacement: Schritt 3, Bild 2 von 3 Razer Phone Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Battery Replacement: Schritt 4, Bild 1 von 2 Razer Phone Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Battery Replacement: Schritt 5, Bild 1 von 3 Razer Phone Battery Replacement: Schritt 5, Bild 2 von 3 Razer Phone Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Battery Replacement: Schritt 6, Bild 1 von 2 Razer Phone Battery Replacement: Schritt 6, Bild 2 von 2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
  7. Razer Phone Battery Replacement, Battery: Schritt 7, Bild 1 von 3 Razer Phone Battery Replacement, Battery: Schritt 7, Bild 2 von 3 Razer Phone Battery Replacement, Battery: Schritt 7, Bild 3 von 3
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
  8. Razer Phone Battery Replacement: Schritt 8, Bild 1 von 2 Razer Phone Battery Replacement: Schritt 8, Bild 2 von 2
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
  9. Razer Phone Battery Replacement: Schritt 9, Bild 1 von 3 Razer Phone Battery Replacement: Schritt 9, Bild 2 von 3 Razer Phone Battery Replacement: Schritt 9, Bild 3 von 3
    • Peel off and pull out the elastic tabs at the bottom of the battery.
  10. Razer Phone Battery Replacement: Schritt 10, Bild 1 von 2 Razer Phone Battery Replacement: Schritt 10, Bild 2 von 2
    • Carefully use the Jimmy to wedge the battery out of the phone.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Bryan
753 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S19-G6, White Winter 2019 Mitglied von Cal Poly, Team S19-G6, White Winter 2019
CPSU-WHITE-W19S19G6
5 Mitglieder
12 Anleitungen geschrieben
5 Kommentare
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Kraytos Barzegar - Antwort
Where can I buy a battery and power button replacement for this phone
Kelly Sales - Antwort
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
Ronald Winfrey - Antwort
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
Wai-Ming Ham - Antwort
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
Raposo morto -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 39
Letzte 30 Tage: 120
Insgesamt: 16,866
