Einleitung
The keycap stabilizers on the Razer Tartarus V2, model number RZ07-02270100-R3U1, can wear out after the keys are clicked many times or too aggressively. This causes the keys to get stuck as the stabilizers are what push them back up after a "click". This replacement guide is designed to help you replace your Keycap stabilizer and extend the overall lifespan of your device.
Was du brauchst
Gently peel off the rubber feet with a Jimmy.
Use a Phillips #0 screwdriver to remove the following screws:
Twelve 6.4 mm-long screws
Two 3.7 mm-long screws
Peel up the bottom left corner of the largest sticker.
Remove the 6.4 mm-long Phillips #0 screw.
Carefully lift the joystick module up and out.
Separate the top and bottom casing of the keypad.
Locate the two rubber stabilizers:
One large stabilizer is positioned under keys 1–19.
One small stabilizer is under key 20.
Carefully pull each stabilizer up by hand from its respective board (motherboard or daughterboard)
