Zum Hauptinhalt wechseln
Razer Wildcat Xbox One Controller Disassembly
Was du brauchst
  1. Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: Schritt 1, Bild 1 von 2 Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: Schritt 1, Bild 2 von 2
    • Use a plastic pry tool to remove the grip plate from each side
    • The plate will release away from the back, not to the side
  2. Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: Schritt 2, Bild 1 von 3 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: Schritt 2, Bild 2 von 3 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: Schritt 2, Bild 3 von 3
    • Cut the sticker covering the center screw and remove it (PH #1)
    • Remove two screws from each grip (PH #1)
    • Use a plastic pry tool to remove rear plate from the controller
    • The three remaining screws on the back plate are PH #1
  3. Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: Schritt 3, Bild 1 von 2 Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: Schritt 3, Bild 2 von 2
    • Remove the M1 & M2 bumpers with two PH #1 screws (red)
    • Unplug the four rumble motors (green)
    • Unscrew the board from the controller with two PH #2 screws (blue)
    • Carefully flip the board until you can get to the ribbon cable
    • Flip the gray clip up to release the ribbon cable
  4. Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: Schritt 4, Bild 1 von 3 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: Schritt 4, Bild 2 von 3 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: Schritt 4, Bild 3 von 3
    • Remove the two PH #00 screws to remove the trigger brackets
    • Slide the trigger pin out just enough to remove it, leave the spring attached
    • The three remaining screws on each trigger are PH #1
  5. Razer Wildcat Xbox One Controller Disassembly, Remove the bumpers: Schritt 5, Bild 1 von 1
    • Remove the bumper assembly from the controller
    • The bumpers detach with two PH #1 screws
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Drew
181 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 55
Letzte 30 Tage: 148
Insgesamt: 284
