Einleitung
Pressing a button and it isn't working? There is a chance that one or more buttons are jammed or broken. This guide will show you how to take apart your Razer Wolverine Ultimate for access to clean and/or repair its face buttons.
Was du brauchst
Place a Jimmy into the crevice between the front panel and one of the back grips, and gently pry the back grip off. Repeat for the other back grip.
Place a Jimmy into the crevice between the front and back panels and pry the back panel away.
Remove all four 4 mm main screws holding the motherboard in its place using a Phillips #000 screwdriver.
Detach the white ribbon cable from the motherboard.
Remove the motherboard from the controller.
For reassembly, follow these steps in reverse order.
