Zum Hauptinhalt wechseln
Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement
Was du brauchst
  1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Front Plates: Schritt 1, Bild 1 von 3 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Front Plates: Schritt 1, Bild 2 von 3 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Front Plates: Schritt 1, Bild 3 von 3
    • Using an opening tool, pry off the the outer front plate.
    • It might take a bit of wiggling and time to loosen it and get it off.
    • Once the front plate is loose, pull it off.
    Frag FixBot
  2. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 2, Bild 1 von 2 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 2, Bild 2 von 2
    • Using an opening tool, pry off the the handle grips.
    • It might take a bit of wiggling and time to loosen and get them off.
    • Once they're loose, pull off the handle grip plates.
    Frag FixBot
  3. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 3, Bild 1 von 2 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 3, Bild 2 von 2
    • Using an opening tool, pry off the Xbox logo plate.
    • Once it's loose, pull off the Xbox logo plate.
    Frag FixBot
  4. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Midframe: Schritt 4, Bild 1 von 2 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Midframe: Schritt 4, Bild 2 von 2
    • Remove ten 9 mm screws from the controller using a Phillips #000 screwdriver.
    Frag FixBot
  5. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 5, Bild 1 von 2 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 5, Bild 2 von 2
    • Using an opening tool, pry off the backplate of the controller. It should come off relatively easily.
    • If it is struggling to come off, you might have missed a screw. Make sure you have removed all screws.
    Frag FixBot
  6. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, D-Pad: Schritt 6, Bild 1 von 2 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, D-Pad: Schritt 6, Bild 2 von 2
    • Look at the inside of the inner front plate.
    • Where the curtains are, pop off the back of the piece that pushes the buttons.
    Frag FixBot
  7. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 7, Bild 1 von 3 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 7, Bild 2 von 3 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 7, Bild 3 von 3
    • Remove three 5 mm screws from the D-pad using a Phillips #000 screwdriver.
    Frag FixBot
  8. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 8, Bild 1 von 2 Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: Schritt 8, Bild 2 von 2
    • Remove the D-pad.
    Frag FixBot
Abschluss
kfrey
97 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 6-3, Botvin Spring 2024 Mitglied von UMass Dartmouth, Team 6-3, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 52
Insgesamt: 990
