Einleitung
Do your hands hurt or slip when riding your scooter? Chances are your handle grips need to be replaced. This guide will show you how.
Was du brauchst
Locate the handle grips at the upper ends of the T-tube.
Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
Repeat for the other handle grip.
Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
Repeat for the other handle grip if installing both.
Let the handle grips dry for 24 hours before use.
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
