Zum Hauptinhalt wechseln
Realigning 12-Inch Bionaire Fan Metal Coil
Was du brauchst
  1. Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 1, Bild 1 von 2 Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 1, Bild 2 von 2
    • Unlock all of the tabs holding the fan cage together.
    • Carefully pull off the cage.
  2. Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 2, Bild 1 von 2 Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 2, Bild 2 von 2
    • Using a Phillips #2 screwdriver, untighten the 1/4'' screw that is located underneath the fan blade.
    • Blade may be sharp so watch out!
    • Cautiously remove the blade from the hinge.
    • Put the screws in a cup so you don't lose them!
  3. Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 3, Bild 1 von 2 Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 3, Bild 2 von 2
    • Rotate the black cap counter-clockwise to disconnect it from the back fan cage.
    • Pull off the back cage from the engine holder.
  4. Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 4, Bild 1 von 1
    • Working with the Phillips #2 screwdriver, loosen the 1/4'' center hinge screw from the metal base.
  5. Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 5, Bild 1 von 2 Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 5, Bild 2 von 2
    • Using the Phillips #2 screwdriver, separate the wire holder from the back of black cover by removing the two 1/8'' screws.
  6. Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 6, Bild 1 von 2 Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 6, Bild 2 von 2
    • Pull of the black knob by rotating the knob counter-clockwise.
    • Pull down the black cover all the way.
    • The coil may pop out after removing the cover.
  7. Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 7, Bild 1 von 2 Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 7, Bild 2 von 2
    • Take out the gold metal spring.
    • Realign the metal coil into designated space.
    • Push the coil in with some force so it rests perfectly in the space.
    • To make placing the coil back in more easier, use the screwdriver!
  8. Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 8, Bild 1 von 2 Realigning 12-Inch Bionaire Fan Metal Coil: Schritt 8, Bild 2 von 2
    • Align the end of the metal coil into the same hole the black wire comes out of in the black cover from step 6.
    • This can be a frustrating step. Be patient!
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 10-3, Green Fall 2015 Mitglied von Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
I have a fan It hum I have to spin the blade for it to start spin
Chris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 3,934
