Was du brauchst
The stop/turn signal bulb is located in the outer rear lamp unit that is secured at the rear of each quarter panel
Open the tail gate and locate the two fasteners holding the light assembly to the quarter panel.
Locate the notches in the outer ring of the fasteners. Those are to facilitate the use of a screw driver to remove the fasteners.
Insert a flathead screwdriver or similar tool and pry out the center of the fastener
A pair of pliers, or similar tool, can be used to get a better hold on the fastener
Completely remove the fastener
Proceed the same way with the bottom fastener. Pry out the center.
Use pliers or similar tool to pull the fastener
Completely remove fastener
The tail light assembly is still held in place by two guide pegs. Gently pull the complete assembly toward the rear of the vehicle to unseat the pegs.
Fully remove the tail light assembly
The assembly can rest on the top of the rear bumper. The Stop/Turn signal bulb is the larger one of the two bulb fixtures.
Remove the bulb socket by turning it about 1/4 turn in a counter clockwise direction
Remove the socket from the light assembly
Remove the bulb from the socket by pulling it straight out.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
What if the trunk don’t open is it possible to change a blinker bulb ?
No. Step 1 picture 2 can't be accessed if it does not open
I'm a female and I will give it a try.
