Einleitung
- If the camera lens is broken, but you can still take photos and videos.
- You should replace the rear camera lens, because your photos are blurry.
- To start the repair, take out the brocken glass shards and place the new lens into the camera bracket.
- Clean the camera bump and re-glue the new lens with double sided tape or two drops of glue.
- This simple repair requires precision because you have to touch the cameras.
- To do the raplacement in the best conditions, equip yourself with safety glasses to protect yourself from glass shards in the eyes.
Was du brauchst
Your Galaxy A 40's lens is broken. Replace it in just a few minutes in order to make good quality images and videos again.
Pull out the little glass shards and be sure not to damage or scratch the camera lenses just underneath.
Pre-glue the new Samsung Galaxy A 40 rear camera lens with double-sided tape or two drops of B7000 glue.
Position this glass lens in its bracket using straight precision tweezers.
Lightly press on the area to fix the lens.
Test your rear camera to confirm the quality of your photos and your videos.
If you are satisfied leave it to dry for an hour.
Bravo! You replaced the lens of your Samsung Galaxy A 40, clean the lens with a microfibre cloth. You can now take pictures and videos normally again.
5 weitere Personen haben diese Anleitung absolviert.
100%
Hier starten ›
