Einleitung
This guide will show how to reconnect the foot support to the wheelchair after it has fallen off.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height. Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height. Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Screw in the bolt to the top socket to secure the height of the footrest.
    • Screw in the bolt to the top socket to secure the height of the footrest.
  4. Screw in the bolt attaching the footrest to the frame. Screw in the lower bolt to the footrest.
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
Abschluss
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
207 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 14-8, Maness Spring 2013 Mitglied von Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Mitglieder
7 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 523
