Einleitung
This guide will show how to reconnect the foot support to the wheelchair after it has fallen off.
Was du brauchst
Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
Screw in the bolt attaching the footrest to the frame.
Screw in the lower bolt to the footrest.
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
