Zum Hauptinhalt wechseln
Recharging A/C Refrigerant for 2016 Hyundai Elantra
Was du brauchst
  1. Recharging A/C Refrigerant for 2016 Hyundai Elantra, Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 1, Bild 1 von 1
    • Get refrigerant and read the pressure chart carefully. This is located on the side of the can.
  2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 2, Bild 1 von 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 2, Bild 2 von 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 2, Bild 3 von 3
    • Find and pull the lever to the hood on the driver's side of the vehicle.
  3. Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 3, Bild 1 von 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 3, Bild 2 von 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 3, Bild 3 von 3
    • Lift the hood while pulling the lever under the center of the hood. Next, prop up the hood with the hood strut.
  4. Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 4, Bild 1 von 2 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 4, Bild 2 von 2
    • Locate the low-pressure port by following the low-pressure hose (the cap will have an "L" on it).
  5. Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 5, Bild 1 von 2 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 5, Bild 2 von 2
    • Shake the can well.
  6. Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 6, Bild 1 von 1
    • Connect the refrigerant hose to the low-pressure port.
  7. Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 7, Bild 1 von 1
    • Start the vehicle and turn on the A/C all the way on.
  8. Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 8, Bild 1 von 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 8, Bild 2 von 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: Schritt 8, Bild 3 von 3
    • While tipping the can 90 degrees back and forth, fill your vehicle (until the gauge reads as the can specifies).
Abschluss
To recharge your vehicle, follow these instructions in order.
Austin Meadowcroft
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 24
Letzte 7 Tage: 167
Letzte 30 Tage: 901
Insgesamt: 8,553
