Zum Hauptinhalt wechseln
RedOctane X-Plorer Auxiliary Port Replacement
Was du brauchst
  1. RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: Schritt 1, Bild 1 von 2 RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Auxiliary Port Replacement: Schritt 2, Bild 1 von 3 RedOctane X-Plorer Auxiliary Port Replacement: Schritt 2, Bild 2 von 3 RedOctane X-Plorer Auxiliary Port Replacement: Schritt 2, Bild 3 von 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Auxiliary Port Replacement: Schritt 3, Bild 1 von 3 RedOctane X-Plorer Auxiliary Port Replacement: Schritt 3, Bild 2 von 3 RedOctane X-Plorer Auxiliary Port Replacement: Schritt 3, Bild 3 von 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: Schritt 4, Bild 1 von 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: Schritt 4, Bild 2 von 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: Schritt 4, Bild 3 von 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
Abschluss
Riley
649 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S17-G1, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Tuesday - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,146
