Einleitung
The RJ-14 connector is designed to connect to pedals that do not come with the device. This guide will show you how to replace the RJ-14 connector located at the bottom of the guitar.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
Pull off the rear case.
Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
Pull off the top shell of the neck to expose the internal features.
Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
Lift the RJ-14 connector to remove it from the case.
