Zum Hauptinhalt wechseln
RedOctane X-Plorer Rubber Button Strip Replacement
Was du brauchst
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: Schritt 1, Bild 1 von 2 RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: Schritt 1, Bild 2 von 2
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 2, Bild 1 von 1
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 3, Bild 1 von 2 RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 3, Bild 2 von 2
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 4, Bild 1 von 1
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 5, Bild 1 von 2 RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 5, Bild 2 von 2
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 1.5 mm Screwdriver
    $5.49
    Kaufen
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 7, Bild 1 von 2 RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 7, Bild 2 von 2
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 8, Bild 1 von 2 RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 8, Bild 2 von 2
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 9, Bild 1 von 2 RedOctane X-Plorer Rubber Button Strip Replacement: Schritt 9, Bild 2 von 2
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
Abschluss
Stephen Haning
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 232
