Einleitung
Over years of use, the rubber button strip in your controller can wear down and become less responsive. Replacing this strip can increase your controller’s lifespan. This guide will demonstrate the process of replacing the rubber button strip underneath the plastic buttons. As long as you follow these instructions precisely, you can replace the rubber button strip without any risk of damage to the controller.
Was du brauchst
Remove the controller's strap, which will be attached at the points in the red circles.
Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
In diesem Schritt verwendetes Werkzeug:Flathead 1.5 mm Screwdriver$5.49
Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
Using your hands, insert the replacement strip underneath the key sensor board.
Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
