Einleitung
The guitar strings often catch on the plastic case or wear over time. This guide demonstrates how to access the internal components of the strings and diagnose hidden problems.
Was du brauchst
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
Pull off the rear case.
Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
Pull off the top shell of the neck to expose the internal features.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
This did not help.
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
