Zum Hauptinhalt wechseln
RedOctane X-Plorer Strum Bar Replacement
Was du brauchst
  1. RedOctane X-Plorer Strum Bar Replacement, Rear Case: Schritt 1, Bild 1 von 2 RedOctane X-Plorer Strum Bar Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Replacement: Schritt 2, Bild 1 von 3 RedOctane X-Plorer Strum Bar Replacement: Schritt 2, Bild 2 von 3 RedOctane X-Plorer Strum Bar Replacement: Schritt 2, Bild 3 von 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Replacement: Schritt 3, Bild 1 von 3 RedOctane X-Plorer Strum Bar Replacement: Schritt 3, Bild 2 von 3 RedOctane X-Plorer Strum Bar Replacement: Schritt 3, Bild 3 von 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Replacement, Strum Bar: Schritt 4, Bild 1 von 1
    • Using two hands, gently remove the two string rod fixtures.
  5. RedOctane X-Plorer Strum Bar Replacement: Schritt 5, Bild 1 von 1
    • Lift up on the strum bar to remove it from the guitar.
  6. RedOctane X-Plorer Strum Bar Replacement: Schritt 6, Bild 1 von 2 RedOctane X-Plorer Strum Bar Replacement: Schritt 6, Bild 2 von 2
    • Remove the string rod by gently pulling it out of the strum bar.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S17-G1, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
This did not help.
michelle Coronel - Antwort
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
Zachary Avery - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 53
Insgesamt: 3,596
